help
Does it need rebuilt? Whats leading you to think it needs it?
Really depends on what you want to do with it, but anywhere from $3500 to $12000 for a motor... More then that if you want to go all out.
Do a compression check... More then likely if its not having any issues starting and little blowby its fine...
Compression check is cheaper then a rebuild...
https://www.dieselbombers.com/ford-p...tml#post756619
well i want to chip it and put bigger injectors in it and was thinking it would be better to redo it before i do that
ok thanks that helps its not really having any but do you think it be bad to chip it with that many miles on it
Exhaust temps (EGT's) are the most important to gauge... Boost is fun to watch sometimes and can help you figure out if you have a boost leak but not needed. If it's an automatic transmission, gauging the trans temp is also important...
