brake fluid in my diesel
Old Jul 12, 2011 | 03:54 PM
Doug cobb's Avatar
Default brake fluid in my diesel
I have brake fluid in my diesel tank, about 4 spoons on a full tank, dont ask how it got in there please. all i want to find out is other than the perfomance that is now verry shoddy, is there any thing else that can or will go wrong before the diesel tank is empty?
Old Jul 12, 2011 | 03:57 PM
BACONBITSFORU's Avatar
Drain it and clean the tank
Old Jul 12, 2011 | 04:04 PM
Doug cobb's Avatar
is there any thing that can be damaged because of the brake fluid
Old Jul 12, 2011 | 04:07 PM
IP injectors change oil and fuel filters it could mess up any thing the fuel went through
Old Jul 12, 2011 | 04:09 PM
Doug cobb's Avatar
will do so, thank you
Old Jul 12, 2011 | 04:19 PM
Make sure after draining and oil change also fuel filter change run some Service Power Clear-Diesel® Fuel & Tank Cleaner.
Power Service Products, diesel fuel additives, prevent gelling, clean injectors, disperse water, boost cetane, reduce emissions, improve fuel economyPower Service Products, diesel fuel additives, prevent gelling, clean injectors, disperse water, boos
Old Jul 12, 2011 | 05:00 PM
NadirPoint's Avatar
A couple ounces of brake fluid in a tank of diesel will do NOTHING. What do you think brake is exactly, anyways?
Brake Fluid
It is NOT the reason OP is experiencing "shoddy performance," whatever that is.
Old Jul 13, 2011 | 02:01 AM
godblessmud's Avatar
Trace amounts of brake fluid will cause you no issues whatsoever.
At one time or another I have run diesel contaminated/mixed with just about anything you can imagine from brake fluid to gear lube.
If your really that concerned just add some 2 stroke oil to the full tank to up the lubricity.
Old Jul 19, 2011 | 12:06 AM
Doug cobb's Avatar
thank you for all the replies. my diesel is in perfect running order again.
i am riding a 2.5 diesel turbo ls 2005
what feul consumpsion should i expect
Old Jul 19, 2011 | 12:10 AM
NadirPoint's Avatar
So, what was the fix?
