1st gen 2wd cummins control arm?
Old Jul 8, 2011 | 04:53 PM
idahoboy07's Avatar
Default 1st gen 2wd cummins control arm?
I was redoing my ball joints. they are the press in kind and I noticed I was replecing replacement ball joints and my new ball joint didn't take much force to press in so I need new upper control arms. Does anyone have any Idea where to get them? I can't find them at the parts store and i cant find them online. Also I took all my tie rods off and now im not sure wich set (inner and outer) goes on which side, how do i tell them apart?
Old Aug 5, 2011 | 08:33 AM
firstgenjunkie's Avatar
Moog part numbers for D series are:
upper control arm shaft kit K7036
upper control arm bushing kit K7006(2 required per truck),
upper control arm bumpstop K7293
I thought most of the tie rod part numbers were marked L and R. OReilly, Advance Auto, NAPA should be able to cross reference the Moog numbers.
right outside tierod ES3122R
right inside tierod ES3123L
left inside tierod ES3123L
left outside tierod ES3122R
For S&Gs are the service manual pages for you.
Good luck!
Attached Thumbnails 1st gen 2wd cummins control arm?-page-1.jpg   1st gen 2wd cummins control arm?-page-2.jpg
Cdog121
Nov 16, 2015 01:49 PM
klaveric
Oct 20, 2015 07:17 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
99RAMS
Jan 25, 2015 11:31 PM
ajpt6.9
Dec 4, 2014 12:06 PM
