47RE Problem!!! Cant drive!
Old Jul 2, 2011 | 12:44 AM
pmariolo's Avatar
Default 47RE Problem!!! Cant drive!
Last night I was towing a trailer that was about 8000lbs and my truck was running perfect without a problem including the transmission. I stopped to take a pee then got back on the freeway and about 30 seconds after that I was on a slight downhill and push on the throttle and had nothing. I pulled over and turned the truck off and let its sit then checked all my fluids and electrical connections. It droved about 30 feet then it did it again like i was in neutral. I ended up getting it towed.
Everytime I start up the truck and go to drive it makes it about 30 feet then like "slips out of gear". I have no clue what the problem is. I was hoping someone else does.
Also I hooked up a code reader and it only throws the two codes that come from the torque converter lock up switch. No shift solenoid or sensor codes.
Old Jul 2, 2011 | 02:17 AM
gradyc's Avatar
It might be a plugged filter.
Old Jul 2, 2011 | 06:59 PM
pmariolo's Avatar
Yea I changed that and cleaned the pressure regulator and manifold. Tranny works even better now
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Mar 19, 2015 08:10 AM
MAC4232
Jan 28, 2015 01:46 PM
signoremint
13
Oct 21, 2014 07:21 PM
