how do you remove the damn turbo down pipe?
Old Jun 29, 2011 | 12:04 PM
ZombieSoldier's Avatar
Default how do you remove the damn turbo down pipe?
OK i am trying to replace my exhaust right now and my damn down pipe wont come off. I have a 4" Diamond eye to put on and i loosened the band clamp thingie where it attaches to the turbo, but alas i can get it off. its almost like its welded on... any advice? once i get that off it should be smooth sailing to get the down pipe, straight pipe and stacks done.... HELP!!!!
Old Jun 29, 2011 | 12:12 PM
PHPDiesel's Avatar
Sponsor
Penetrating lubricant and some time to soak.
Then a small pry bar between the housing flange and the clamp lip.
Old Jun 29, 2011 | 12:43 PM
CSIPSD's Avatar
Most times when I find one stuck, a little shot of BP blaster and if you just wait a second....
Ping...
and it pops off all by itself.
LOL
Old Jun 30, 2011 | 11:44 PM
ok shot with some pb blaster and will try it again tomorrow.
Old Jul 2, 2011 | 01:16 AM
fordornothing's Avatar
mine came off no problem. except the bolt was pointing towards the fire wall.
Old Jul 2, 2011 | 09:52 AM
OceanDiesel's Avatar
Same issue with my '96 and '99
Old Jul 2, 2011 | 01:05 PM
well i got the new down pipe on, and the straight pipe, but my hole cutting saw wont cut through the bed. yes i got one made for sheet metal...
Old Jul 2, 2011 | 01:30 PM
Captain Call's Avatar
Slow the drill down and tip it ever so slightly. Then when the saw breaks through work it accordingly. I've done it that way for years and has always worked for me.
Old Jul 2, 2011 | 01:48 PM
cant.. it wore off the teeth.. i have to get a new one..
Old Jul 2, 2011 | 01:51 PM
Sounds like you had it on too high of a speed.
