Torque converter lock switch in 1st and 2nd
Old Jun 24, 2011 | 04:13 PM
pmariolo's Avatar
Default Torque converter lock switch in 1st and 2nd
I have a 97 cummins and installed a torque converter lock switch a couple weeks ago. It only works in 3rd and 4th depending if I have the od on or off. But when I manually put the tranny in 1st or 2nd the lock switch doesnt work. My buddy has a 96 cummins and his will lock in all four gears if he manually shifts. we cant figure out how his does it because we seemed to install it all the same way.
Does anyone know what I did or didnt do?
I only want it to lock in 1st and 2nd because we have some steep fire roads near by and it just seems easier if its locked. Also when I get on it when it shifts into third it just feels like i lose power until i lock the converter then it takes another 5mph to really start pulling again. so i would like to be able to lock it in 2nd so i dont have that little loss in power.
Old Jun 24, 2011 | 06:59 PM
Tweaker727's Avatar
The stock valve body for the 46 and 47RE dosen't allow 1st and 2nd lock up,
you'd have to go the aftermarket route' like a sun coast,
Old Jun 24, 2011 | 08:06 PM
cummin_un_glued's Avatar
FormerVendor
i have a 47re with a lockup switch and it locks 2nd gear.....
Old Jun 24, 2011 | 08:36 PM
pmariolo's Avatar
How do you have the lockup installed?
Old Jun 27, 2011 | 11:44 PM
FormerVendor
grounded thru a toggle t-tapped onto the harness at the pcm
Old Jun 28, 2011 | 06:29 PM
pmariolo's Avatar
thats how mine is installed.
Old Jun 28, 2011 | 08:37 PM
turbo2332's Avatar
dont shift with the switch flipped unless you have billet shafts.
Old Jun 29, 2011 | 07:23 PM
FormerVendor
shifted locked with stock shafts for 2 years with 150hp injectors and a edge juice....slipped the trans but never broke a shaft.....now it has a billet input
Old Jun 29, 2011 | 07:33 PM
turbo2332's Avatar
its just not good for things. flex plate included. cool till it breaks though
Old Jun 29, 2011 | 09:49 PM
pmariolo's Avatar
I usually let off a little when i shift while locked. But i still cant figure out why some of you can lock your second gear and i cant. since the stock valve body doesnt allow it.
I have my transmission relay removed and jumper wire in there, would that change it because a lot of you dont have it hooked up that way.
Pike
Jan 25, 2015 10:38 PM
myago92
Oct 17, 2014 08:50 AM
