How-To: Brighten Your Vehicles Headlights
Old Jun 21, 2011 | 05:30 PM
Diesel Bombers's Avatar
Staff Reporter
Default How-To: Brighten Your Vehicles Headlights
How-To: Brighten Your Vehicle’s Headlights
Wiring With RelaysHave you ever tried to run a welder, air compressor, or battery charger plugged into a long extension cord? It doesn’t work very well. The reason it doesn’t work well is due to the length of the wire connecting the tool to the power source. Using a long wire (or extension cord, in this case) means increased electrical resistance, which means not enough power to get the job done. If you own an older truck (built before 1998), you probably have a long series of wires that stretch from the battery to the fuse box to the headlight switch on the dash, and then back to the headlights. By adding a relay, you effectively create a shortcut for the electricity. This means more power for your headlights, because of the decrease in wire length (and resistance). In our case, the battery was less than 1 foot away from the headlights, so adding relays made perfect sense.
Photo Gallery: How-To: Brighten Your Vehicle’s Headlights - Diesel Power Magazine
How-To: Brighten Your Vehicle’s Headlights | Digg It | Add to del.icio.us
More...
Old Jun 25, 2011 | 04:10 AM
jeniD4u's Avatar
Never tried this thanks for the information will try this and let you know whether it worked perfectly fine or not.
Old Jul 3, 2011 | 08:50 PM
Jax Rhapsody's Avatar
Yeah headlight relays are pretty common. That or HIDs.
Old Jul 4, 2011 | 02:01 AM
jeniD4u's Avatar
Hii,I tried the way you said firstly I was confused and it didn't went that way but after 5 attempt it does worked fine.Thanks for the information ,its really working and I got to learn this new technique.
Old Jul 19, 2011 | 02:01 AM
EasternAggie's Avatar
HID kits can be bought from DDM tuning (a prominent HID company) with lifetime warranty for under $50. Most kits are 35w, I paid $70 for my 6k 55w which light up the night.
Old Jul 19, 2011 | 11:48 PM
Or you could check out theretrofitsource.com for real good HID equipment. While we're on the subject, might wanna make sure the lenses are clear and clean to or it'd be pointless.
Old Jul 20, 2011 | 06:02 PM
I switched out my factory headlights for clear aftermarkets. Not as good of a beam as projectors, but couldnt find a projector setup that didnt look ricer-ish on my truck.
Old Jul 21, 2011 | 12:30 AM
Most of those are halogen projectors anyway. The retrofit source only sells hid equipment for you to retrofit your headlights with. Check out HIDplanet, nice setups there. Looks like you got a ford. Yeah the bigger the headlight is, it seems the ricer they make them when it comes to anything involving a projector. An angel eyed halogen projector with LEDs on one side like sideways eyelashes or other lame ****.
carid
Diesel Bombers Sponsors
Apr 7, 2015 07:30 AM
Mar 2, 2015 05:10 PM
Dec 15, 2014 03:00 AM
Dec 12, 2014 12:30 PM
Dec 2, 2014 03:10 AM
