Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
whining noise
Old Jun 20, 2011 | 12:01 PM
langleymetalworks's Avatar
Default whining noise
I know that noise issues are hard to describe, but I will do my best. I replaced the CP3 pump and all went well, except when under a load I am hearing a new deep whiing noise. It is not turbo noise it is almost like a powersteering pump whine when it is low on fluid. It only does it under load no matter the RPM. Can a cracked or damged resonator on the turbo cause this noise, or could it be the O-rings on the intake pipe? Any suggestions please. Thanks
Old Jun 21, 2011 | 09:47 PM
BriteWhiteRam's Avatar
small exhaust leak, I had a very similar sound as you are describing, a high pitched whining, it ended up being the two bolts on the exhaust end of the EGR cooler were loose, I must not have got them tightened back up when we had the heads off, but it was really disconcerting, and it only happened under a load, I was almost sure my turbo had grenaded
Just check things out thoroughly, could be something as simple as a loose bolt or two
Old Jun 22, 2011 | 07:11 PM
Thanks for the heads up. I did check those bolts after you replied and they were pretty tight. I am afraid if I tighten them more I will break the stud off. Do you think it is possible that the gasket is bad. If so I think I will just put a block off plate in it.
Old Jun 26, 2011 | 01:30 PM
its possible, get someone to press the throttle while the hood is up to see if you can pinpoint the issue first
RedCummins
Apr 6, 2015 11:15 PM
Boatman
Mar 20, 2015 10:00 AM
Dak_summers
Jan 22, 2015 08:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
