06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
DURAMAX EGR BLOCKER PLATE
Old Jun 12, 2011 | 09:41 PM
johnnyrock's Avatar
Default DURAMAX EGR BLOCKER PLATE
HAVE A 06 DURAMAX WAS LOOKING INTO THE EGR BLOCKER PLATE AND FINGER STICK KIT,
WAS WONDERING IF ANYONE HAS INSTALLED ONE AND IF IT IS WORTH IT? I OWN A SMALL TREE SERVICE AND DO ALOT OF HEAVY TOWING AND LOOKING TO ADD SOME MORE TOWING POWER. IM ALSO LOOKING FOR A PROGRAMMER AND WANTED TO KNOW THE BEST ONE OUT THERE?? ANYONE WITH ANY SUGGESTIONS FOR CHEAP POWER GAINS?? THANKS
Old Jun 12, 2011 | 09:57 PM
jbrown1132's Avatar
welcome to db. the blocker plate is worth doing to keep the sooty exhaust gases from being recirculated back into your truck's intake, the plate will cost about $12. don't even worry with the finger stick especially if you are considering a tuner. now you asked for the best tuner and the best tuner known for your duramax is called efilive, but ppe and quadzilla are pretty good canned tuners.
Old Jun 12, 2011 | 10:21 PM
johnnyrock's Avatar
WILL THE PLATE SET OFF ANY CODES IF I DO IT WITHOUT A PROGRAMMER FOR NOW? IM LOOKING FOR WAYS TO GET BETTER PERFORMANCE FOR TOWING, MPG, AND RUN COOLER ENGINE AND TRANS TEMPS. I HAVENT DONE ANY MODS TO MY TRUCK YET. I PLAN ON KEEPING THIS TRUCK FOR AS LONG AS POSSIBLE AND WANT TO START DOING ANYTHING THAT WILL HELP PROLONG MY ENGINE AND TRANS. I WORK AROUND LOTS OF DIESEL ENGINES MOSTLY HEAVY EQUIPMENT, HEAVY TRUCKS AND TRACTORS. ALL MECHANICAL ENGINES, I AM JUST NOW GETTING INTO THE ELECTRONC DIESELS SO ITS A WHOLE NEW BALL GAME. GET NERVOUS MAKING MODS BECAUSE ITS MY WORK AND DAILY DRIVER. THANKS FOR YOUR HELP AND ANY FURTHER SUGGESTIONS.
Old Jun 12, 2011 | 10:23 PM
turbostang7's Avatar
efilive! the only way to go on a dmax! they do have some tuners that are good but with efilive you will never "outgrow" it. you can always change the tunes as needed
oh and you will need the programmer that will allow you to delete the egr or your truck will not be happy
Last edited by turbostang7; Jun 12, 2011 at 10:23 PM. Reason: Automerged Doublepost
Old Jun 12, 2011 | 10:30 PM
johnnyrock's Avatar
THANKS FOR HELP GOING TO LOOK INTO THAT PROGRAMMER. THANKS AGAIN JOHN
Old Nov 29, 2011 | 10:30 PM
mikes454's Avatar
i put in the blocker plate w/ a finger stick.works great as long as you can solder and tee into wires no problem.i have edge juice so i had to use a finger stick.i want to do the intake grid heater delete(major power gains as long as you dont live in snow/supercold), but there is no finger stick for that so i have to get efilive first.
Old Dec 4, 2011 | 08:56 AM
2500HeavyDuty's Avatar
Running a plate without a tuner will cause a lot of problems. Dnt do ut unless you can get rid of the fault codes
Old Dec 11, 2011 | 07:10 PM
coppertop's Avatar
go efi live
Old Dec 12, 2011 | 10:50 PM
BriteWhiteRam's Avatar
no problems... just one code, p0403 insufficient egr flow, thats not a problem is the CEL doesn't bother you
Old Dec 13, 2011 | 02:26 AM
That's a problem for me
