Headlight issues
Old Mar 28, 2007 | 07:33 PM
Ram96SRT's Avatar
Default Headlight issues
Well I just got the truck out of storage and I am ready to install my sport headlights...but,
Im having problems with my low beam lights. when I turn the lights on, I have no light in the low beam setting. when I flip the high beams on both lights light up. could the low beam filament in both be burnt out? is there a problem with my headlight switch? whats my problem?!
thanks for the help.
Ram96SRT
Old Mar 28, 2007 | 11:59 PM
mobs241's Avatar
how did you wire them in? sounds like the lowbeam isnt being triggered.
Old Mar 29, 2007 | 03:20 PM
Ram96SRT's Avatar
these are the stock lights...i havent put the sports in yet...
Old Mar 29, 2007 | 06:09 PM
mobs241's Avatar
i doubt both filimants went out. but try that.. find someone with a truck similar and start with bulbs, if thats not it try the headlights switch.
Old Mar 29, 2007 | 07:24 PM
Do you have a multimeter?
Kind of hard to do much troubleshooting without a schematic.
Old Oct 13, 2010 | 11:49 PM
Marine's Avatar
I have the same problem starting 2 nights ago; low beams don't work but high beams do. It is not the headlight switch; I tried a different one. It is not the bulbs; i replaced both of them.
Next thing to try is the dimmer switch.
Old Oct 13, 2010 | 11:57 PM
rednekroper05's Avatar
check the wires at the back of the multi function switch thats were my problem was
Old Oct 14, 2010 | 10:48 AM
Marine's Avatar
You are talking about the main headlight switch on the dash? What was your problem and how far from the switch? Were the wires rubbed or broken?
Thanks,
Old Oct 14, 2010 | 10:58 AM
turn signal/washer/ hi lo switch on the steering wheel
my problem was that i could only get the headlights to work when i held back the lever and several other problems with headlights working and not working
i found a loose wire in the plug on there( the solder on the conector inside the plug broke allowing the wire to move around)
Old Oct 14, 2010 | 11:02 AM
Marine's Avatar
Ok, I thought I would get that clarified. That was next on my list to check out.
Thanks.
