Losing coolant DuramaxLLY
Old Jun 7, 2011 | 07:51 AM
Dhorngrabber's Avatar
Default Losing coolant DuramaxLLY
My 2005 lly has 250g on it and I'm losing coolant but can't find a leak I had a problem with an injector and replaced the seals and it's running but I'm still losing coolant. Any ideas?
Old Jun 7, 2011 | 09:39 PM
jbrown1132's Avatar
you may have to look from underneath, look at the water pump this is usually the problem. if there is no sign of water leak at water pump, clean the cap on the over flow tank. also see if the top rad hose is hard after the truck sits overnight, hard hose is a good sign of a head gasket leak.
Old Jun 9, 2011 | 06:12 AM
Is the coolant supposed to be in the injector sleeve? If not how do you seal it?
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
