LB7 duramax smoking at idle
Old Jun 7, 2011 | 01:15 AM
wuntun's Avatar
Default LB7 duramax smoking at idle
My 2004 duramax is skipping and smoking at idle, is there something specific i should do or look at? I have used all the old fuel and did fresh fill-up, changed fuel filter, there has never been any codes thrown. Your help would be appreciated. Thanks in advance.
Old Jun 9, 2011 | 06:45 PM
SCDiesel's Avatar
FormerVendor
what color smoke? that would be a good start.
Old Jun 9, 2011 | 07:27 PM
bobcat67's Avatar
9 times out of 10 it's injectors on these motors
Old Jun 9, 2011 | 07:30 PM
redneckpipeliner's Avatar
I have a buddy that his started smoking and got worse and worse and worse, had a crack in the intake, Dusted.
Old Jun 9, 2011 | 10:35 PM
biged681985's Avatar
i would bet its the injectors?
Old Jun 9, 2011 | 11:21 PM
wuntun's Avatar
the smoke is light gray. thanks for the answers. I finally took it to the stealership, and to be sure and 88 bucks later they say 4 7 and 8 are leaking. (into cyl. not oil) How can they specify the leaking cylinders with only a obd 3 hook-up? I call BS. but now on to ordering my long overdue performance injectors. I am open to suggestions on what to buy. Thanks.
Old Jun 10, 2011 | 12:15 AM
Thats what my buddys truck was doing, and the dealer did the same thing and said the same thing and told him he was down 30% on power.
Old Jun 11, 2011 | 05:48 PM
440ctd's Avatar
you can pop test the newer diesels using certain scan tools. my snapon can
Old Jun 12, 2011 | 10:34 AM
BriteWhiteRam's Avatar
its the injector balance rates that they can test with the GM tech II, I can check it with my EFI live as well
If the injector balance is +/-4 in park or +/-6 in gear then the injector is out of balance and is usually a sign of a cracked injector body, grey/blue smoke is a very clear indicator of a bad injector or two
I suggest getting new Bosch injectors unless you're planning on making well over 500hp, they are a waste if you only want 500hp or less
Sep 7, 2015 07:30 AM
Bamafantrey
Chevy/GMC Duramax 01-04 LB7
Aug 24, 2015 09:30 AM
duramaxtuner
Diesel Engine Conversions
17
Jun 1, 2015 10:41 AM
Oleoleson
Mar 28, 2015 06:20 PM
DanielC559
8
Nov 21, 2014 06:59 PM
