Useing coolant
Old May 27, 2011 | 12:59 AM
ssgstank's Avatar
Default Useing coolant
I have a 96 K3500 crew dually and it uses about a quart of coolant every 150 miles.There are no puddles of coolant were I park, it has good power, no bubbles in the coolant bottle or steam from the exhauste I.E. none of the normal blown head gasket indicators. Any ideas about what is causing this.
Old May 27, 2011 | 04:42 PM
Crazy's Avatar
look around heater hose near T-Stat they like leak and from the heat you won't see the coolant
Old May 27, 2011 | 07:01 PM
ssgstank's Avatar
O.K. thank you I might just replace the hose to elemenate it as a possible cause.
Old May 27, 2011 | 07:15 PM
Boiler01's Avatar
My first truck was an 83' 6.2 diesel and it had the same problems. It would run fine but towards the end it was using about 1 gallon of coolant/day. It turned out to be a cracked block/head, can't remember which right now long time ago.
Old May 27, 2011 | 10:21 PM
Crazy's Avatar
80's diff set up from the 90's
Old Jun 12, 2011 | 01:24 PM
ssgstank's Avatar
Turns out this was the water pump it was leaking from the lower weap hole and I could not see it. The pump started to sqeak and the leak turned in to a steady flow when the system was topped off.
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
