no start/hard start
Old May 26, 2011 | 09:33 PM
99stackedpowerstroke's Avatar
Default no start/hard start
a buddie of mine has a 2000 3/4 ton and we replaced the seals in the hpop and its ran fine for the week and now when you start it all it does is crank, tach moves no smoke, when the fuel bowl builds pressure theres a hissing noise like its sucking air, stops when pump shuts off, i replaced opr thinking that could be problem but nothing, fuel bowl is full and so is hpop res. any ideas????
Old May 26, 2011 | 10:15 PM
Riffraff Performance's Avatar
FormerVendor
Do you have access to an AutoEnginuity or other scanner?
Old May 27, 2011 | 05:05 PM
not right off hand probably cant get one for a few days or a week
when/if it does start it runs perfect! anybody have any ideas?? could the hpop have gone bad??
Last edited by 99stackedpowerstroke; May 27, 2011 at 05:05 PM. Reason: Automerged Doublepost
Old May 27, 2011 | 05:37 PM
95powersmoker's Avatar
I doubt it. HPOP wouldn't be intermittent like that...
Old May 27, 2011 | 05:40 PM
then maybe the fuel bowl or line or seal??
Old May 27, 2011 | 05:44 PM
Is he getting a Check Engine light at all?
Old May 28, 2011 | 05:17 PM
no sir, just when the key first turns on like normal
maybe fuel filter?? does anybody else have an idea?
Last edited by 99stackedpowerstroke; May 28, 2011 at 05:17 PM. Reason: Automerged Doublepost
Old May 28, 2011 | 06:29 PM
Get it on a scanner. Anything else is just pissin in the wind...
Old May 29, 2011 | 05:42 PM
okay since i cant get a comp on it, i got to looking and pulled the fuel bowl off and got to looking at everything cleaned it all up, i noticed a small little hair line crack on the inside of the fuel bowl where the top fuel lines screw to the fuel bowl, i know i need to replace this BUT could this cause the hissing and no start?
Old Jul 25, 2013 | 02:26 PM
finn188's Avatar
I know this is an old post but I am wondering if you ever found the solution. I have the same hiss and no start. I can sometimes tap on the fuel pressure regulator and it fires right up and runs perfect but sometimes no. I ordered a regulator rebuild but looking for any other posibilities to rule out. Thanks!
