1994 chevy 2500 6.5 turbo diesel
Old May 24, 2011 | 10:27 AM
dieselcruzzer17's Avatar
Default 1994 chevy 2500 6.5 turbo diesel
i got a 94 chevy silverado with the 6.5 in it. i put it away last winter running pulled it out about two weeks ago wont start. i have no fuel to the injecters. but i have fuel ell the way to the ip. i have checked all fuses grounds and connections. even replaced both batteries. i have read it could be the pmd or the ip but the motor was just rebuild 40,0000 miles ago. anyone with info please help asap!
Old May 31, 2011 | 09:54 AM
jasonduke5's Avatar
Check the fuel shut off. It is on you IP pump. Sometimes from sitting it will stick shut.
Old Jun 1, 2011 | 10:15 AM
how do you tell if the shut off is stuck shut? i pulled it out too look at it all i saw was the little spring and the rubber damper at the end of the spring. also could it be electric? like the pmd or a short in the wiring
Old Jun 2, 2011 | 08:01 PM
jasonduke5's Avatar
Have someone turn the key to the one and it should click and move. I can hear mine from in the truck when i turn the key. But yes could be electrical
Old Jun 3, 2011 | 09:58 AM
thanks for the help it does click so it looks like it should be working properly. i got fed up trying to figure out the problem so i just took it up to my mechanic ill let you know what it was when its fixed. is there really any upgrades for the turbo or the ecm that arent going to coast an arm and leg. also what guages are most common to be run with this truck?
Old Jun 3, 2011 | 01:23 PM
jasonduke5's Avatar
I made a manual boost controler for mmy turbo and got rid of the vacum waistgate. But more then that it costs alot of money
Old Jun 3, 2011 | 06:16 PM
Crazy's Avatar
Boost , EGT and Trans some run fuel psi or vacuum gauge
when you get boost and EGT make sure you get boost that goes to 30psi not 60 and with EGT that goes 1500 deg not 2500 deg
Brclouse
Nov 18, 2015 08:44 AM
Devon7.3
Sep 27, 2015 10:35 PM
greatlakes diesel
Feb 13, 2015 09:55 PM
ssmith.77
Jan 11, 2015 02:03 PM
Snoobly
Dec 11, 2014 11:59 AM
