injectors
Old May 24, 2011 | 01:43 AM
powerstroke312's Avatar
Default injectors
how do i tell what code injectors are in my truck?? were at on the injector would it tell you? thanks
Old May 24, 2011 | 02:56 AM
joebob3093's Avatar
Moderator
on the top of the solenoid it should say. what year is your pickup?
Old May 24, 2011 | 03:29 AM
its a 97 shopuld have 130cc split shots i believe but im replacing the motor with a 96 and just wanted to make sure i was swapping injectors for no reason
Old May 24, 2011 | 09:20 AM
95powersmoker's Avatar
Yep, it says the code right on top of the injector solenoid... Should have a long code starting with either AA or AB...
Old May 24, 2011 | 10:18 PM
joebob3093's Avatar
Moderator
a 97 can either have AAs or ABs. AAs are 90cc single shots and ABs are 120cc split shots.
Old May 24, 2011 | 11:22 PM
97 has ad amd the 96 has AOs?
Old May 24, 2011 | 11:25 PM
No... AD's came in late 99+ Superduty's...
AO's are the same as AA's and are usually found in the earlier OBS trucks...
Old May 25, 2011 | 12:23 AM
joebob3093's Avatar
Moderator
AOs came in the very early powerstrokes. mine was built 10/03/94 and it had AOs when i opened it up. the AAs came im most OBS pickups. ABs came in the 96? and 97 OBS cali modles and the early 99. the ADs are 99+
Old May 25, 2011 | 12:35 AM
Im positive they have are ADs possibly aftermarket? Its dam quick and smokes alot
Old May 25, 2011 | 12:47 AM
AB's did come in the Cali models 96 and 97 and the early 99...
Also, My 95 had AO's.
Somebody could have swapped them in there.
