stroker wont start
Old May 22, 2011 | 04:11 PM
buckie2's Avatar
Default stroker wont start
Guys HAVE A 01 POWERSTROKE REPLACED STARTER THIS MORNING AND TRUCK STARTED RIGHT UP AND RAN FINR . DROVE 20 MILES PARKED TRUCK AND NOW WONT START. PLENTY OF FUEL IN TANK CHECKED FUEL PUMP RELAY AND FUEL PUMP RESET BUT STILL NOTHING.ANY IDEAS TRUCK IS SETTING IN PARKIMG LPT OF LOCAL RESTAUARANT AND NEED TO MOVE IT.
Old May 22, 2011 | 05:14 PM
99stackedpowerstroke's Avatar
what does it do when you try and start it? do you get white smoke out of exhaust? does the tach move?
Old May 22, 2011 | 06:22 PM
buckie2's Avatar
turns over strong dosent smoke or anything like that
Old May 22, 2011 | 08:24 PM
no white smoke or anything?? did you check to see if you have fuel in the fuel bowl and what does the filter look like??
Old May 22, 2011 | 09:52 PM
95powersmoker's Avatar
Make sure to check the level of the HPOP... Should be withing about 1/2" of the top..
Old May 23, 2011 | 09:40 AM
buckie2's Avatar
Guys here is my senerio have replaced starter in this truck 3 times since 06 starting last week had to tap on starter to bump it figured bad spot on starter. Finally starter did nothing . crossed lugs on starter itself and stater would kick out but not crank motor. tested starter at auto zone and they said starter was in good condition but replaced it anyway because of life time warranty. put new starter on started right up drove 20 miles shut truck off and started it right back up every thing fine. left truck sit for 5 hours went to start and does nothing but turn over. but while trying to start sometimes battery gauge goes up to half way and sometimes when wts light was on just the gauge would barely raise above 8 just wandering if baterries may not be strong enough and i have been wearing this starters out. now baterries are dead from trying to start.
Old May 23, 2011 | 09:44 AM
It's possible the batteries are bad, I would get them load tested at least to rule it out...
Old May 23, 2011 | 02:39 PM
POWERSTROKEMANIAC's Avatar
true that and maybe if that dont work, could be a glow plug problem
Old May 23, 2011 | 02:41 PM
PSD-BLACK-CLOUD's Avatar
I had a 6.0 that acted kinda like that and it was my alternater.
Old May 23, 2011 | 02:44 PM
That could be it too. Mine went out last summer. It would start but it took forever to. eventually it just stopped cuz my battery got low so get that checked too advance or auto zone will do it for free
