Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Synthetic Oil
Old May 21, 2011 | 07:30 PM
sherrie123's Avatar
Default Synthetic Oil
Having a hell of a time with my engine in my 2006 F350 SD and it was suggested to me to use synthetic oil.
After three stores I find out it is an uncommon thing to do, mainly because of cost.
Does anyone use synthetic? If not, what is another alternative as my research has turned up I have the crappiest engine ever.
BTW, I live in Edmonton, AB temperatures varying from +30 celcius to -40 celcius.
Old May 21, 2011 | 07:35 PM
LORDDiESEL's Avatar
It's not a bad engine once you work some of the bugs out.
Hit up walmart for oil. I run the rotella T6 synthetic.
They also have the rotella T 15w40 dino oil there in the 20L jugs.
Old May 21, 2011 | 07:57 PM
sherrie123's Avatar
I think the last kind i put in was the Rotella T triple protection but found at canadian tire.
Looked at walmart for synthetic oil didn't find, but then again I know not all stores carry the same items.
Lorddiesel, u have the same engine? Any suggestions? Already have done the EGR cooler delete kit and a couple other minor items under the hood.
Last edited by sherrie123; May 21, 2011 at 07:57 PM. Reason: Automerged Doublepost
Old May 21, 2011 | 10:11 PM
LORDDiESEL's Avatar
where in canada are you? Victoria BC here. Yes, i have a 06 F350 powerjoke as well.
What problems are you having? The EGR delete is one of the best mods to do. Oil cooler rebuild is on the list as well.
A cheap mod is a coolent bypass filter. I posted my in the fluids/oils forum. it's pretty cheap and very easy to do.
Old May 22, 2011 | 12:01 PM
Deezel Stink3r's Avatar
Wow, with this outside temperatures you are on the safe side with syns. They cover a wide temperature range and will maintaining shear stability. That means the vicosity will remain under these circumstances.
I go with Synthetics. They keep the engine clean, wipe the oil off and you can eat of it.
The only difficulty I explored is the leak seaking ability of syns. Syns will remove the dirt and sludge out of every nock and cranny- so it can start to leak. At least mine did. But an afternoon, every seal and gasket replaced and now I couldnt be happier.
Syns give me the extra insurance without to deal with those insurance guys.
vin_diesel
Sep 15, 2015 11:25 AM
1stgenSWB
Aug 13, 2015 12:19 AM
soco
Jul 27, 2015 06:06 PM
sjslhill
Jul 22, 2015 01:02 PM
coors_man_2005
Dec 15, 2014 10:23 AM
