no power
Old May 16, 2011 | 06:21 PM
fordornothing's Avatar
Default no power
So I was driving my moms truck today. It's a 97 cc lb 4WD. Auto trans. it has a rednecked 4" straight pipe on it and a K&N filter in the stock box. It is just a turd. I mean it took almost a mile just to get up to 65 MPH What could this be?
Fresh oil& filter change with new fuel filter.
Last edited by fordornothing; May 16, 2011 at 06:21 PM. Reason: Automerged Doublepost
Old May 17, 2011 | 07:35 PM
95powersmoker's Avatar
Hard to say... Is it a 49 state truck or cali truck?
Old May 18, 2011 | 06:50 PM
white93's Avatar
When that happens to the 7.3's at work its time for injectors. I would first check the ebpv and then fuel pressure before you go buying injectors.
Old May 18, 2011 | 07:10 PM
It's a49 state to my knowledge. and it doesn't seem like it's lacking on fuel delivery. it idles smooth. accelerates smooth. but jus not fast at all. and it shouldn't need injectors at 155,xxx miles...
Old May 18, 2011 | 08:29 PM
No, injectors should be fine... COuld just be a stock truck, they are dogs... 90cc injectors. 15* hpop... That's just what they are.
Old May 19, 2011 | 07:22 PM
i got a 94 powerstroke. when i first got it it was totally stock. and i could beat hers any day of the week. and that was with 2 dead injectors. i had a bully dog 6 pos on it. it helped a little. but it made more smoke than power. and put it at about 10 mpg with a lite foot.
6 pos was on moms pickup...
Last edited by fordornothing; May 19, 2011 at 07:22 PM. Reason: Automerged Doublepost
Old May 19, 2011 | 08:03 PM
Are you saying there is a chip on your moms truck and it still feels underpowered?
The 94 with a chip is still about 60hp more than a stock truck. So yes it has more power.
Old May 20, 2011 | 04:05 PM
Well i had it on moms. but it really didn't add much. the "40" hp setting you couldn't tell a difference. "60" hp was what i ran most of the time. the "75" hp you couldn't even use. it would do awesome for the first 50 feet. then the fuel pump couldn't keep up. i wasn't immpressed at all with it.
Old May 20, 2011 | 07:59 PM
farmingsthelife's Avatar
hmm, that is really odd. I would check that fuel pump though, maybe you got a bad lift pump?
I'm not a genious, but maybe you had a bead lift pump from the start and it is just finally wearing down to it's last bit? I really don't know just throwing that out there. These use a mechanical pump though, I beleive.
Last edited by farmingsthelife; May 20, 2011 at 07:59 PM. Reason: Automerged Doublepost
Old May 22, 2011 | 12:22 AM
well on the other settings it didn't seem like it was lacking on fuel delivery. but yes, it is a mechanical pump. i'm thinkin about geting her a intake, exhaust, and ts chip. that should help a bit.
