Edge JWA question
Old May 14, 2011 | 01:17 PM
tworks's Avatar
Default Edge JWA question
Just a quick ? What is the difference between "hot unlock" and not, and is it worth the price. Can it still be used if the pump has been tapped. thanks pt.
Old May 14, 2011 | 01:24 PM
RAW's Avatar
RAW
I don't think Hot Unlock will make a difference if you haven't tapped the pump. I found it does make a difference adding level 6. It's advertised as 14 more HP, but the torque curve is more aggressive.
Old May 15, 2011 | 11:52 AM
01quadcab's Avatar
just tap that pump then in a year add the hot unlock once the newness wears off
Old May 16, 2011 | 09:19 PM
tworks's Avatar
Thanks for the info. Now to try to find a good price on one. Maybe i should look for axhaust/air intake/EJA kit?? Who on this sight do I talk to?? thanks pt
Old May 26, 2011 | 08:30 AM
tworks's Avatar
I have my EJWA installed now What are some acceptable paramiters that i should be setting up the modual with, for daily driver, and towing...limits...alert settings ... back downs ect?? thanks pt
Old May 26, 2011 | 09:44 AM
RAW's Avatar
RAW
I liked driving on level 3 when I had just the EJWA. I would set the alerts as followed:
Trans Temp, 220*
EGT (pyro) 1250*, upto 1400* if you like to hammer on it for short burst and dont want to hear the alarm.
Boost, 40 PSI
I would also suggest turning the cold engine protection on as well.
Old May 26, 2011 | 10:06 AM
Farmboy 2.0's Avatar
I agree with Ryan, Definitely turn the cold engine protection on it will keep your engine happy. And the turbo timer is nice as well
Old May 27, 2011 | 08:25 AM
tworks's Avatar
thanks guys. wiil give it a try with my trailer this weekend. have a good one. pt
justinsbeck
Jan 18, 2016 12:15 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Kfohne21
For Sale
Dec 23, 2014 04:17 PM
somarillw
Dec 8, 2014 09:07 PM
CumminsCrazed
Oct 27, 2014 09:02 PM
