truck won't start
Old May 12, 2011 | 10:15 PM
wvo gmc's Avatar
Default truck won't start
I have a 2000 gmc 6.5 tbd 2500 that makes a clicking/ buzzing sound under the dash when I try to start it. The problem began when I tried to use an electric charger/starter to get it running. Now besides the noises the Clock/radio won't turn on, the glow plugs aren't making the noise that they use to and the lift pump clicks but doesn't run as long as it should. So far I've tried cleaning the terminals and cables, checked fuses, and tried recharging batteries. I had the batteries checked a few months ago and I will do it again asap.
Thanks in advanvce for any help.
Old May 16, 2011 | 06:33 PM
wvo gmc's Avatar
Default update on 6.5 gmc
I cleaned the terminals again and no progress. I have read that the electric charger/starters can damage the electrical system, but I don't know which component is damaged and causing the problems. Does anyone know what would make the clock/radio not turn on with the ignition?
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
