6.4L Performance Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels Related to Performance and Longevity
DPF Removal Guide
Old May 12, 2011 | 03:57 PM
greenesayle's Avatar
Up DPF Removal Guide
good afternoon! does anyone know of a DPF removal guide, walk-thru, or step-by-step pictures of any kind for a 2008 F250?
Thanks!
Old May 12, 2011 | 04:10 PM
Farmboy 2.0's Avatar
What programmer you thinking of going with?
Old May 12, 2011 | 04:15 PM
I'm not sure. have a stealth2 on my dmax but i am not happy with it. i dont want to spend a ton because i mainly want it just for the delete but i do want something that will be reliable. what do you recommend?
Old May 12, 2011 | 04:17 PM
The H&S XRT hands down would be the best for what you wanna do. And for the Duramax either the H&S Products, Edge EVO Races, or the PPE Hot Race
Old May 12, 2011 | 04:21 PM
thanks! i'll take a look at them. i opened the links in your pm but the shopping cart was empty
Old May 12, 2011 | 04:24 PM
Ah Crap!!! I can send ya the links again
Old May 12, 2011 | 05:11 PM
Looks good! Is the installation about the same as my 08 dmax?
Old May 12, 2011 | 05:23 PM
Yeah with the XRT Pro you need to make sure that the coolant in the truck is warm when you downlaod the XRT ( For some reason it seems that they download better). Also when it comes to the selecting is the dpf installed in the vehicle you need to select NO that way it downloads the delete software. After the programmer is fully downloaded you can now remove the exhaust system from the truck and unhook all the sensors from the wiring harness and remove and unplug the hard steel lines from the dpf. With any of the H&S programmers you do not need to put the sensors back into the pipe.
Old May 13, 2011 | 09:47 AM
thanks. i think i want to go with the xrt and a 4" turbo back
are the 08-10 fords as easy as the 08 chevys to do the complete exhaust swap out?
the reason i ask is because i've heard ppl say its hard to get the exhaust off the down pipe on the fords
Last edited by greenesayle; May 13, 2011 at 09:47 AM. Reason: Automerged Doublepost
Old May 13, 2011 | 10:54 AM
Yeah the downpipes can be a b****h. Most of the time we just sell the downpipe back exhaust systems because the factory dp are designed quite well for a factory down pipe IMO.
