converting dodge to diesel
Old May 9, 2011 | 07:31 PM
Kimball Kreation's Avatar
Default converting dodge to diesel
I just bought a 1999 dodge 2500 4X4 truck with a v10 motor i want to do one of two things. the truck has a bad motor and tranny.
OPTION 1: I have a military 6x6 deuce and a half, I really want to put the motor, tranny, transfercase, and front end and rear end in my dodge truck. is this at all possible? im measuring it up and want to know if anyone has done it. Maybe I should keep the dodge front end and rear end in it.
OPTION 2: I want to put a second generation cummins 24valve motor in my dodge, will the tranny and transfercase need to be changed with the v10 motor or can I use it. If I want to use a cummins motor and tranny will my v10 transfercase bolt to it?
Last edited by Kimball Kreation; May 9, 2011 at 07:37 PM. Reason: had another idea
Old May 9, 2011 | 07:45 PM
95powersmoker's Avatar
Welcome to Diesel Bombers, I'm moving this thread to the conversion section...
Old May 9, 2011 | 08:49 PM
59cummins67's Avatar
what kind of transmission does it have now i just did a v10 cummins swap on my 94 and mine is a 4x4 5 spd and the tranny and driveline between the the v10 and cummins is the exact same i dropped a 12v in mine and the mounts where in the same location
Old May 10, 2011 | 03:32 PM
beerbellykelly's Avatar
put a cummins in the dodge-it,s how god intended things to be-
with the deuce-drop the rear axle,fit a trailer body,and then get some HEMMT wheel and tires on there-they call it ' a bobbed deuce ' you know you want one-
Old May 10, 2011 | 04:22 PM
FTE's Avatar
FTE
Now I want one!
Old Jun 22, 2011 | 02:45 PM
DIRTYDAN's Avatar
What is involved in doing the V10 to Cummins swap?
Old Jun 22, 2011 | 08:14 PM
Apmcrx's Avatar
V10 out, Cummins in. Trans stays. Remove the fuel pump from the tank and just have a line running in there with a filter on the end. Done!
Old Jun 23, 2011 | 08:34 PM
DIRTYDAN's Avatar
Kewl.
How about the radiator? Can it stay?
cass_epp
Wanted To Buy (WTB) - Used
Mar 20, 2017 04:07 AM
Jet A Fuel
Aug 3, 2015 10:45 AM
elbedonie
May 19, 2015 10:16 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
