turbo question
Old May 3, 2011 | 07:31 PM
fravelj's Avatar
ATTN turbo question
i got a new turbo and put it in it lasted two days and it was blowing oil out exhaust i took it off and tore it apart and the seals are still good i was thinking that whoever put it together messed up cus i put it back together and it spun free but not quiet as free but im thinking the snap ring on the turbine exhaust wasnt in right? its supposed to keep oil in right? and i had to take a short piece to put on the mounting bracket drain thing and i might have had the hose to long and was making oil back up?
Old May 3, 2011 | 07:59 PM
DieselCrawler's Avatar
which turbo kit did you get? also before you put the kit on, a good idea is to take a screwdriver and punch a bunch of holes in the velley pan inside the grommet where the turbo drains.
Old May 4, 2011 | 06:56 AM
fravelj's Avatar
i just got a t3 t4 hybird turbo and what does punching holes in the pan do?
Old May 4, 2011 | 07:19 AM
alows the oil to return back into the motor quicker.
what kit is on the motor though? ats, banks, hypermax?
Old May 4, 2011 | 08:51 PM
fravelj's Avatar
i just got a t3 t4 hybird turbo and take a screw drive thru the gromet hole and drive it thru? what does that do? and is that the reason for it blowing oil out exhaust is cus the oil drain was backed up?
im using same set up that came on that 94 that i took it off of i just got a new turbo so whatever kit is from the factory and is that the reason for oil to be blowing out exhaust?
Old May 4, 2011 | 09:42 PM
could be. or the turbo is junk.
Old May 5, 2011 | 04:25 PM
fravelj's Avatar
i tore the turbo apart and everything checks out nothing wrong everythings there
Old May 5, 2011 | 06:21 PM
cant help ya then but. no idea.
Old May 22, 2011 | 10:20 AM
fravelj's Avatar
by me punching holes in the valey pan it wont hurt it if i have to put it the way it was with out the turbo ?
Old May 23, 2011 | 05:07 AM
yea it will. it will pull more oil out and bacjk into the intake.
