97 powerstroke motor conververtion
Old Apr 26, 2011 | 12:56 AM
powerstroke312's Avatar
Default 97 powerstroke motor conververtion
io have a 97 powerstroke had stage 1 injectors 4 inch turndown straight pipe to six inch stack edge chip with 287xxx miles and blew head gaskets!!!! was either thinking about gettin my buddys 01 powerstroke and either putting tht motor in my 97 or my 97 cab on the 01 any suggetions on which way i would be better off doing? thanks appreciate it! JEREMY
Old Apr 26, 2011 | 01:02 AM
EasternAggie's Avatar
I would imagine switching the motors would be easier. Theres a guy running around Stillwater that has a newer 7.3 in his OBS truck.
Old Apr 26, 2011 | 01:34 AM
do u know if the motor mounts are the same? would i need the 01 tranny and t-case also?would i have to relocate the motor trans and t-case(forward/backwords)?any issues with the 01 harness and computer in the 97? also need to get around 500 horsesany suggestions? thanks u guys are awesome!!!
Old Apr 26, 2011 | 02:51 AM
joebob3093's Avatar
Moderator
there is nothing diffrent from 94-03 other then some internal and computer changes. you will have to swap the wiring harness to get it to run right. but all the mounts and everything is the same. for 500 horse you will need injectors, turbo, headstuds, springs and push rods, clutch or tranny, custom chip, intake, exhaust.
Old Apr 26, 2011 | 04:33 AM
Are the mounts the same? I would imagine the mounts for a 99-03 7.3 would not work with a 97 and down frame.... are you saying he can just reuse the mounts from his old engine and mount them on the new one? That would make sense, but I really dont have any personal experience in the area
Old Apr 26, 2011 | 10:38 AM
95powersmoker's Avatar
As JoeBob said, the blocks are the same...
You will need to switch to Electric fuel on your truck because the SD motor doesn't have the lobe on the cam... You will also need to add an intercooler if you plan on sticking with the SD Spyder... The wiring harness and computer need to be swapped over.
Check to make sure that block has forged rods or it aint worth all the work.
Old Apr 26, 2011 | 10:50 AM
CSIPSD's Avatar
2001... PMR's more then likely.
I have a 97 motor in my truck right now... Block, heads are more or less the same.
Old Apr 26, 2011 | 11:37 AM
"2001... PMR's more then likely.
I have a 97 motor in my truck right now... Block, heads are more or less the same. "
what year is your truck? would i be better off having my motor out of my 97 rebuilt?or can i get more power out of the sd 7.3?
Old Apr 26, 2011 | 11:40 AM
What's wrong with your motor that you are trying to replace it?
Old Apr 26, 2011 | 11:53 AM
My 97 blew ahead gasket and the heads are messed up and the motor has a bunch oof mmiles so I was thinking it would be a lot cheaper to just put the sd motor in it
