New Injectors
Old Apr 25, 2011 | 10:20 PM
chrisf97305's Avatar
Default New Injectors
I am looking at a new set of injectors to have built.
Have anyone used AB code injectors?
Or what should I be looking for in a performance injector?
I want enough fuel for the upper 500 or lower 600 hp range.
Old Apr 25, 2011 | 10:26 PM
95-SimpsonOBS's Avatar
i personally like hybrids. i know a guy who put 238/100 hybrids in his 2000 7.3 and 2 weeks ago he had 596RWHP on a dyno. he told me they have enough juice to turn the twins hes getting ready to put on and if you think about it, its 238 CC of fuel, thats a lot.
Old Apr 25, 2011 | 10:28 PM
95powersmoker's Avatar
You are going to want some big hybrids... 250/200 is the injector I want when I jump into a SD... Depending on the turbo, those will put you in your range.
AB's are just 120cc split shots... Nothing special. I ran some in my truck for about a month.
Old Apr 25, 2011 | 10:37 PM
joebob3093's Avatar
Moderator
i would go with some where around a 250/200 or 300/200, that should put you pretty dang close to 600
Old Apr 25, 2011 | 10:40 PM
OK,
Give this old guy some education.
Whey you say hybrids, what exactly do you mean?
What makes a injector a hybrid?
Old Apr 25, 2011 | 10:42 PM
CSIPSD's Avatar
Originally Posted by chrisf97305
OK,
https://www.dieselbombers.com/ford-p...ease-read.html
Read this sticky... It will help.
Also, dont I know you from other forums? If your sponsered by EIS, then you should know what hybrids are...
Old Apr 25, 2011 | 10:44 PM
joebob3093's Avatar
Moderator
he is the one who built the bad twin turbo setup on his black OBS
Old Apr 25, 2011 | 11:06 PM
Thanks for this, This helps me a lot. Yes EIS does build my injectors, Not real sure what he does but it does work. The sticky realy helps me understand what the different injectors are.
Old Apr 26, 2011 | 05:24 PM
CSIPSD's Avatar
I had EIS injectors... I had to send them elsewhere to get fixed.
I hope he has gotten better over the years.
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
