Diesels On The Dyno Diesel Discussions of Dynoing , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST EVENTS IN THIS SECTION*
stock 12v dyno
Old Apr 25, 2011 | 05:18 PM
elephantrider's Avatar
Default stock 12v dyno
just info for comparison sake...
dyno'ed my 02 club cab le @
relentless diesel in willis tx, bone
stock, with the star wheel all the
way in. a518 auto. all it could
muster up was 149 hp / 353 tq.
sure feels like more than that
when rolling down the road. not
MUCH more, but a little
Old Dec 29, 2011 | 07:08 PM
well, not sure why i just saw this,
but its my 92, not my 02
Old Dec 30, 2011 | 06:52 PM
white93's Avatar
That's not bad for a stock 19 year old truck. I never dynoed my 93 stock but it puts out pretty good for the little it has done. 1 turn on the screw, Bhaf, 3" intake elbow, 56 comp wheel, 16 cm housing, 4" exhaust= 246hp?/605 ft/lbs. Not fast but it runs with the stock common rails.
Old Dec 30, 2011 | 08:25 PM
i put a he351 on it, and plan on getting some 75hp
sticks, ahead of the dyno im gonna hit in march.
hopefully that will get me 200hp or so.
Old Dec 31, 2011 | 08:09 PM
white93's Avatar
I had 75hp sticks on mine about a year ago, I think they were 4 hole tips. They burned clean and didn't really smoke too much with the pump turned up a bunch which I liked. The only reason I took them out was they ran too hot towing heavy trailers with my turbo. Those will make your truck come alive especially with the 351.
Old Jan 4, 2012 | 08:09 PM
im hoping to get a goo bump with
bigger injectors only.
Old Jan 10, 2012 | 06:58 AM
just ordered a m&h #4 pin
Old Jan 14, 2012 | 02:16 PM
got the #4 pin installed. now before, i already had the star wheel
bottomed, so when i got the new pin installed, the get up and go
disappeared until you got to around 1400 rpm. popped the cap off
and adjusted the smoke screw almost 3 turns, and that got the low
end power right back. runs really good now. i'm seeing almost 30
lbs of boost @ just over 1k egt.
Old Jan 15, 2012 | 06:52 PM
white93's Avatar
Good deal . How's the smoke with that pin? Ive read that its real smokey down low.
Old Jan 15, 2012 | 08:36 PM
with stock injectors its not smokey at all.
just the tiny-est bit of haze @ wot, and
thats with stock sticks.
