Losing Coolant
Old Apr 24, 2011 | 04:59 PM
BobbyCann's Avatar
Default Losing Coolant
I have a 05 F350 with 109k miles. The other day i had white smoke coming out the tail pipe, so i cleaned the EGR, added (Sea Foam) to the fuel and crankcase and it stopped but I'm still losing coolant. Its not in the oil where is it going.
Old Apr 27, 2011 | 09:43 PM
heavy hauler's Avatar
Probably going to be your EGR cooler. I would recommend doing away with it completely.
Old Apr 29, 2011 | 08:28 PM
Yanez's Avatar
EGR cooler The inner pipe is probably cracked. Known point of failure. Someone makes an upgrade for it, a heavier duty one if you want to stick with the cooler. It's a bitch to take off and replace.
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
