Truck died wont start
Old Apr 21, 2011 | 06:00 PM
jcampbell's Avatar
Sad Truck died wont start
Please any advice would be great new to this computer gig so I drive an 01 chevy duramax truck ran great for a few thousand miles but was driving and just died wont start any ideas would be great seems like its not gettin fuel How do u check fuel pressure or know if pump is workin
Old Apr 24, 2011 | 09:38 AM
cummin_un_glued's Avatar
FormerVendor
new fuel filter would be first but it should have went to running bad before it died with that, if it just all of a sudden shut off i would lean more toward the FICM being bad
Old Apr 28, 2011 | 12:42 AM
jcampbell's Avatar
Okay. So I have had great luck with truck so far besidesit having bad injector. From what I've been told and sounds like. I bought it with just over 200,000 miles Drove it for years knockn. Every once in a while. Seemed like truck would freak out and not allow engine to go over 1800 rpm. I would shut truck off. And it wouldn't do it for six months. Then about two months ago it started doing it frequenly almost everyday. Seemed to when I got on the gas. Well I went to NASCAR race in Dallas. Only beig able to get up to sixty. Was along drive. Made it almost home and bam. Truck dies will not start. We pulled it home. I changed the filter just a few hundred miles back. Im pretty good with engines. So I figured that if u unscrewed filter and cranked fuel should flow out. I opened lines were they go in and out of that computer lookin box by filter thinkn if u crank it fuel should fly out if pump is pumping. Nothin. Seems like bad pump. Is there anything that tells not to pump. It is mechanical right. I don't know what ficm is. Please help. Any ideas. I got to get truck goin. Boat can't get to lake without it Pleeeeeasse any advice.
Okay so I did some research if ficm is bad shouldn't I still get pressure. After crankn engine. Were lines go in fuel. I think should be blowin out. Seems like pump. But can't afford to just change on hunch. Some advice ideas please. I'm driven my drift car daily. But no Ac. Fun but hot in texas
Old Apr 28, 2011 | 01:19 AM
2500HeavyDuty's Avatar
the symptoms you were describing it sounds like your cp3 took a crap on you. but further diagnosis will help identify what happened.
fyi there is no supply pump that pushed fuel to the injection pump that sits in the valley of your engine, the injection pump has its own suction pump that draws fuel all the way from the tank. after changing the fuel filter you have to prime the system by using the hand pump on the top of the fuel filter housing and bleed screw.
the computer looking thingy with the fuel lines going though it is your Fuel Injection Control Module
doublehbar
13
Aug 9, 2015 12:35 AM
moose2j
Jun 21, 2015 12:36 AM
doublehbar
33
Jun 5, 2015 11:38 AM
clarthom
8
Mar 5, 2015 07:27 PM
ronstop
Feb 26, 2015 09:48 AM
