LB7 Duramax really bad MPG
Old Apr 21, 2011 | 05:59 AM
urabus's Avatar
Default LB7 Duramax really bad MPG
Hi.
i have LB7 2002 Duramax, it´s a federal motor(no EGR system). my problem is that he spend so much fuel. Mpg is around 8-10 gallons on every 60miles.there is no hard start,black smoke or nothing. when i read it with TECH 2 there is nothing i can see that is wrong or out of specs. I can feel a lack of power but not so much.sometimes on highway driving i can feel missfire or it feels that way. is some that can help me? gallon i iceland is around 8 dollors so this is killing my and i´m starting to hate my DURAMAX.. not good.. hehe...
Old Apr 21, 2011 | 08:31 AM
biged681985's Avatar
it sounds like injector problems. have you checked your oil to see if your making oil? u need to hook the truck up to a good scanner have have the injectors tested
Old Apr 21, 2011 | 08:47 AM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
Check to see what your making for rail pressure at idle and wide open throttle. If your pressure is low the truck will not burn the fuel correctly causing a lack of power and milage. If your not seeing a haze(smoke at idle) or fuel in the oil your injectors might be alright. Do a balance rate test. If non of them are + or - 4.0 or higher your alright.
Old May 11, 2011 | 03:08 AM
urabus's Avatar
now i have code P1781 transmisson control module. ????
Sep 7, 2015 07:30 AM
Bamafantrey
Chevy/GMC Duramax 01-04 LB7
Aug 24, 2015 09:30 AM
Smokin Joe
Mar 29, 2015 12:18 PM
Oleoleson
Mar 28, 2015 06:20 PM
Back-in-Black
Nov 29, 2014 12:40 AM
