What adapter for a 0M671 to AX15
Old Apr 19, 2011 | 10:30 PM
berg's Avatar
Default What adapter for a 0M671 to AX15
did a search and got confused..
What adapter will take me from a om617 to a Jeep AX15 5 speed manual trans?..
while were on it can you use the jeep clutch- flyweel etc?
Old Apr 20, 2011 | 01:07 AM
deck60's Avatar
there are several on here i am doing a chevy myself check these out compilation of OM617 swap projects
Old Apr 20, 2011 | 09:22 AM
berg's Avatar
no Jeep conversions on that list...
Old Apr 20, 2011 | 08:55 PM
jeep-dsl's Avatar
The website is OM617 Mercedes Diesel Conversion Jeep Wrangler Cherokee TJ YJ Engine Adapter Swap Yes you use Jeep starter, flywheel, clutch and pressure plate all stock Jeep stuff. Transmission stays in original position in Jeep.
Old Apr 21, 2011 | 01:16 PM
deck60's Avatar
that makes it ay too easy
Old Apr 21, 2011 | 05:47 PM
FTE's Avatar
FTE
Hey Deck60, how close to driving your rig are you?
Old Apr 27, 2011 | 01:10 AM
jackson1's Avatar
I think,Jeep Aisin-Warner AX15 Transmission is a perfect adapter.Because,this adapter assembly makes for a strong and convenient adaptation of classic.And it's easily and quickly installed onto the AX15.
Old Apr 27, 2011 | 07:14 AM
deck60's Avatar
fte working on getting a slave cyl to work have had engine running on the tand once i ge that going I am shooting for July I want to do it right
Old Apr 27, 2011 | 08:51 AM
Corvette74's Avatar
deck60
The 410's did not work out on the interstate turned to many rpm at highway speed.
I don't have a tach on it but I can tell it is turning to much.
I am going to put a set of 373's in tonight to see what that will do.
will keep you informed.
vette
PS first check on mileage was 33 mpg but will be better on next check with these gears.
Old Apr 28, 2011 | 12:43 AM
deck60's Avatar
not bad for mileage
