got 1st, 2nd gear an thats all?? need help
Old Apr 18, 2011 | 08:01 PM
whiteley's Avatar
Default got 1st, 2nd gear an thats all?? need help
I have a 95 Dodge 2500 turbo diesel with a 5.9 I'm havein problems with the tranny. Stopped at a red light everything was workin right. When i took off I only got first an second.. The throttle position sensor shows voltage 5.00: I had a computer hooked up to the truck an the throttle % stayed 0 even when I mashed the pedal??? I need some advice before I just go a rebuild my tranny for no reason.
Old Apr 19, 2011 | 12:03 AM
manny31's Avatar
check t.p.s the hard way with paper clips. go to tst website shows how to do it. Almost sure t.p.s is no good not tranny. Good luck
Old Apr 19, 2011 | 12:19 PM
daveO's Avatar
I would def check out the TPS. Here's some good info:
Dodge diesel maintenance tips
Scroll down almost halfway.
Old Apr 19, 2011 | 05:30 PM
jdjanetka's Avatar
You should have a 47RH tranny which operates hydraulically for first thru third. tps should only affect od and lock up. not saying that the tps is good. voltage at idle should be around 1 volt with it going toward 5v at full throttle but you need to be checking the right wires. no third gear could be valve body issue or like mine was a seal which did not allow the piston to be applied.
corksil
Aug 2, 2015 10:19 PM
aoutlaw95
Mar 3, 2015 09:02 PM
Pike
Jan 25, 2015 10:38 PM
rtbcoop
Nov 29, 2014 11:33 PM
myago92
Oct 17, 2014 08:50 AM
