6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
gear shifter
Old Apr 17, 2011 | 10:43 AM
legs8803's Avatar
Default gear shifter
Got a 06' 350 w/ 6.0! When I put it in gear the dash shows its still in park. Goes in and out of all gears just fine but dash always show park. How can I fix this?? I figure the dash is a pain to take apart>>??
Old Apr 17, 2011 | 11:25 AM
csdiesel's Avatar
I have a manual trans, you can get the dash out by pulling it straight out a couple of inches then unplug every thing. from there on im shure its a linkage .if that helps
Old Apr 17, 2011 | 10:28 PM
ntmdtr3fan's Avatar
Look under the dash. there is a small cable with a (black) adjustment turner on it.. You can adjust it that way. If it dont move going into low gear then the cable could be broke.
It should be right on the stearing column underneath the dash.
Old Apr 18, 2011 | 08:42 AM
Mdub707's Avatar
The cable from the shifter moves the transmission lever and selects the gear. The cable has nothing to do with the orange marker on the dash moving or not. If you pull the dash off, unplug everything, there is a few bolts holding the instrument cluster on, you can pull it out of the way pretty easy and look in there and see what is going on.
I just went through all of this, my trans cable broke on my truck.
Jun 4, 2015 09:30 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:27 AM
Mar 19, 2015 08:10 AM
rtbcoop
Nov 29, 2014 11:33 PM
Nov 6, 2014 08:10 AM
