injector recomendations......
Old Apr 16, 2011 | 12:02 PM
2500hd Duramax Freak's Avatar
Default injector recomendations......
finally realized i need to change out the injectors on my 04 lb7. was wondering if anyone could recomend the dynomite diesel performance injectors with the 50hp nozzles. i am running a banks six gun tuner with the pda device and a straight 4" exhaust from the block back (no cat converter) to a 5" exhaust tip. also have an AFE stage 2 air intake. thanks
Old Apr 16, 2011 | 12:44 PM
BriteWhiteRam's Avatar
stock New Bosch injectors...
50hp nozzles aren't gona do much for a truck like yours, the stock injectors can already overfuel the stock turbo, you will just end up with more smoke and higher EGT's not more power
Old Apr 16, 2011 | 03:43 PM
2500HeavyDuty's Avatar
go with stock
Old Apr 16, 2011 | 08:20 PM
BRE's Avatar
BRE
x2
Old Dec 25, 2011 | 05:30 PM
Dirtystackss's Avatar
How mutch more power are stock injectors good 4 over stock setup
Old Jul 12, 2012 | 09:23 PM
Spurrit's Avatar
What size are the stock ones?
Old Jul 12, 2012 | 09:36 PM
S Phinney's Avatar
Its useless to go over sized without changing to EFI live tuning.
Old Jul 13, 2012 | 10:00 PM
No... Its useless because they will supply more fuel than the stock injectors which is pointless because the stock turbo cannot supply enough air to burn the extra fuel, the stock injectors are able to easily provide enough fuel for 500hp
Old Jul 14, 2012 | 04:28 PM
S Phinney's Avatar
Simply put if the guy wants oversize injectors then he need to custom tune it perform properly.
Old Jul 15, 2012 | 02:06 PM
waste of time and money for a mostly stock truck IMHO, this thread is months old anyway, this guy has probably already made up his mind and never came back
