6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Gauge install HELP!!
Old Apr 13, 2011 | 07:00 AM
DieselPower84's Avatar
Default Gauge install HELP!!
Okay, I know where and what to do with the pyro and fuel pressure gauges, but what about the oil and coolant temp? For oil temp I read about drilling a hole in the oil pan, but isn't there a better/easier way like in the return line or something on that order? For coolant temp, where would be the best place for that? Thanks in advance!!
Old Apr 13, 2011 | 03:36 PM
kidn1980's Avatar
hope this helps, i myself just got a water gauge but don't know where to install.
Gauge Installations at DieselManor- 2003-2007 6.0L Powerstroke
Old Apr 13, 2011 | 04:47 PM
Thank you, I did see this before and it did help with the pyrometer. I wish they would have something like this for the engine oil and coolant temp though.
Old Apr 13, 2011 | 09:49 PM
kidn1980's Avatar
this is what they sent me for coolant
Install Pictures
Old Apr 14, 2011 | 06:56 AM
Okay, thank you!! That will be helpful!
Old Apr 15, 2011 | 08:22 PM
ranger518's Avatar
I put my coolant temp sensor in my coolant filter works.great and ic you don't have a coolant filter get one would not have a 6.0 without one
Old Apr 16, 2011 | 09:41 AM
Yea I do want to get one, but I just spent all this money on the gauges right now.
Old Apr 17, 2011 | 01:59 PM
ranger518's Avatar
Well then I would just save yourself a. Lot of troubble and wait untill you install a coolant filter before you hook it up if not I rink the only way is to drill and tap the t stat housing or you can put it in the driver side block drain but you will need a addapter.
Old Apr 18, 2011 | 03:18 PM
I was going to just put it in the block at the service port. That is something to thing about though. Thanks!
Old Apr 19, 2011 | 07:52 AM
Mdub707's Avatar
Yeah I'd put it right in the block. What gauges did you get? My EV2's came with a bunch of different adapters to make it work. Haven't checked to see if there is one that will fit in the block yet, but I'd imagine it will.
