Adj Boost Elbow
Old Dec 11, 2007 | 08:08 PM
sawmillman's Avatar
Default Adj Boost Elbow
adj boost elbow worth the money with a stock turbo or keep saving of a bigger turbo.
Old Dec 11, 2007 | 08:33 PM
ndurbin's Avatar
Yeah their worth the money, can get ya an extra 10-15 lbs. of boost.
Old May 15, 2009 | 07:14 AM
cummins6spd's Avatar
there only like 30 dollars, if you tighten the screw will you get more boost
Old May 15, 2009 | 05:22 PM
sstockton's Avatar
You don't want to push more than about 32PSI with a stock turbo, and honestly that depends on the RPM you are turning at that boost level as well. You will start pushing the compressor out of its map, and rapidly decreasing efficiency. However, up to about 32psi at around 2500-2600rpm and you're still golden. I would definitely recommend a boost elbow to anyone with a stock charger and a mildly bombed truck. Or even a non adjustable elbow set to 32psi.
Sean
Old May 18, 2009 | 08:30 AM
so if you tighten that screw will you push more boost? can you tighten it all the way down, or will that jack stuff up?
Old May 20, 2009 | 10:09 PM
bowtech's Avatar
you can it will give more boost but as they said after 32 you start to get negative affects with a stock turbo
Old Jun 3, 2010 | 12:37 AM
801SANT's Avatar
where exactly do you install the boost elbow at???
Old Jun 3, 2010 | 05:53 AM
94 12valve's Avatar
there should be a air line either from the afc or from the compressor housing going into the wastegate.
Old Jun 3, 2010 | 08:06 PM
85_305's Avatar
Being Evaluated
You can tap the turbo inlet, screw the boost elbow in. Attach it to the WG. Cap off the afc line. Done.
Old Jun 4, 2010 | 03:29 PM
whoabeats's Avatar
Just get a needle valve from napa its part number 6820 only $8 and it will do the same exact thing except it can be turned by hand
