94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
New mechanical fuel pump not workin
Old Apr 7, 2011 | 09:39 PM
smokinstroke's Avatar
Default New mechanical fuel pump not workin
Not sure if my long block cam doesn't have lobe. What electric fuel systems are out there
Old Apr 7, 2011 | 09:43 PM
95powersmoker's Avatar
Have you verified that it doesn't?
Beans has a kit. But you will pay for it...
You could build a DIY kit for less than half of the kit.
Old Apr 8, 2011 | 04:19 AM
Not yet waitin in hospital for second son to arrive, so I thought I would do some research while waiting. Someone said there was a rod to transfer from old pump to new one, but they looked the same to me.
Old Apr 8, 2011 | 08:27 AM
twinboys's Avatar
look into switching to a super-duty type set-up. I have an electric standard pressure pump on the frame, the stock fuel filter (and return)set-up, and finally through a super-duty (higher pressure) pump. There are variations on this including completely removing the stock fuel bowl.
Old Apr 8, 2011 | 11:00 AM
That is awesome. Congrats on the soon to be addition to the family.
When you do get back to the motor, you need to verify that it has that lobe. Might even stick something in the hole and turn the motor over to see if it goes up and down.
Old Apr 8, 2011 | 04:39 PM
Thank you will do
Old Apr 14, 2011 | 11:27 PM
marty robbins's Avatar
Has anyone tried this unit ?? Banjoe Block Fuel Upgrade for OBS Ford Powerstroke ebay 260763788168
Old Apr 14, 2011 | 11:35 PM
Looks like it just replaces the factory one? I don't see a need... After watching that companies youtube videos where the ran an electric fuel pump on the frame feeding a stock OBS fuel bowl which isn't designed for those pressures, I wouldn't buy anything from them...
By the way... Welcome to DB!! Don't forget to fill in your signature with your trucks information.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
RatsMC
May 4, 2015 05:25 PM
MREILLY
Apr 8, 2015 01:27 PM
moneypitk5
Feb 12, 2015 11:01 AM
