advancing timing
Old Apr 1, 2011 | 10:31 PM
HAYMAFIA's Avatar
Default advancing timing
96 cummins. have engine on tdc and have pinned the pump. how do i advance the timing? i have the snap on timing kit. do i turn the pump or the engine? which way do i turn the engine or pump? i believe the factory timing is 13.5 degrees
Old Apr 3, 2011 | 05:59 PM
BRE's Avatar
BRE
You run the motor over until the reading on your gauge shows what timing you want then seperate the gear from the pump and roll the motor back to tdc and re-seat the pump gear.
Old Apr 3, 2011 | 06:49 PM
pukie370's Avatar
one trick i realized is to losen nut on gear before seting pump, or it will change when breaking loose, and clean the shaft good or you will do again.
Old Apr 3, 2011 | 06:53 PM
BRE's Avatar
BRE
Yes that is a helpful hint. I use ether (spelling?) to clean my shafts.
Old Apr 3, 2011 | 08:38 PM
daveO's Avatar
Worked great for me too!
Old Apr 3, 2011 | 08:58 PM
HAYMAFIA's Avatar
thanks guys i got it. i used brake cleen and compressed air to dry it off. set it to 17* have the mighty diesel head bolts
Old Apr 4, 2011 | 03:49 AM
BRE's Avatar
BRE
Let us know how ya like it and how it changes things up
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
91 7three
Nov 14, 2014 10:37 PM
jjbced
Oct 26, 2014 09:09 PM
