94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Truck dies after idling for extended periods then putting into Drive
Old Mar 30, 2011 | 12:27 PM
85_305's Avatar
Being Evaluated
Default Truck dies after idling for extended periods then putting into Drive
So what seems to be happning, in more instance than one, is that if I'm idling outside (15-20*f lately) for several minutes.. half hour to 45mins... and then I put the truck into drive, it instantly shuts down. I put the truck in neutral, restart it, put into drive, seems like nothing ever happened. Wtf?
Matt
Old Mar 30, 2011 | 05:42 PM
95powersmoker's Avatar
So if you don't idle it that long, is it fine?
Old Mar 30, 2011 | 05:48 PM
CSIPSD's Avatar
Before you put it in drive, give the throttle a little blip... See if that helps. I have seen that happen before and it was a sticky IPR and the truck just freaks...
Just a little blip, not WOT or anything.
Old Mar 30, 2011 | 06:06 PM
85_305's Avatar
Being Evaluated
Yep sure the hell seems this way
Will-do!
Also, perhaps irrelevant, but once I was offroading and I hit deeper mushy ground.. while I was very lightly on the throttle I put the manual t-case into 4hi... as soon as I popped it in, the truck instantly died. I figured it was normal that maybe the truck shut down so it didn't tear apart the t-case or something?
Old Apr 8, 2011 | 02:55 PM
DaneF's Avatar
Ipr nut loose and when goin in drive it slides back enough to quit? Ive had that before.
Old Apr 8, 2011 | 04:29 PM
85_305's Avatar
Being Evaluated
Nd how would I check this?
Old Apr 8, 2011 | 04:32 PM
prison's Avatar
open the hood ipr on the back of hpop. should be a nut on it
Old Apr 8, 2011 | 11:22 PM
85_305's Avatar
Being Evaluated
Oicic. Leav eit to smart erik! But ok I'll check my nut out tomorrow and report back folks
Aug 17, 2015 02:10 PM
May 28, 2015 02:10 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Feb 17, 2015 11:50 AM
Oct 21, 2014 02:40 PM
