Does your truck leak oil?
Old Mar 30, 2011 | 07:33 AM
Bill10656's Avatar
Default Does your truck leak oil?
As above my truck always leaves tiny spots of oil, whenever i clean the engine up i can never find where it comes from and its really annoying. a freind has a 98 24v and it does the same but he doesn;t worry about it. Is it normal for these cummins to drip a lil? also the tranmission occasionally drips a bit but never loses anything on the stick. are there any common parts i coudltry tightening to sort these problems out or is it just part of living with a Cummins?
Old Mar 30, 2011 | 07:48 AM
Red_Rattler's Avatar
High Tech Redneck
Very common for sure... But my 12v doesn't leak anymore (fixed a few gaskets)
Old Mar 30, 2011 | 08:30 AM
NadirPoint's Avatar
Assuming you don't actually have seals or gaskets going bad, that's typically just blowby residue dripping from the draft tube.
Old Mar 30, 2011 | 02:45 PM
oldblues's Avatar
hi
very small ammounts , does not leae a mark sometimes
Old Mar 30, 2011 | 03:07 PM
superbee1970440's Avatar
+1. look for a big open hose/pipe right next to the starter. You'll usually see small drips around the opening of the tube.
Old Mar 30, 2011 | 04:57 PM
Bill10656's Avatar
Yeah the blow by tube drips a little but thres also a bit on the block further forward but the course is very tricky to track down. i know my dip stick tube has a smashed end and doesn't seal up right, so i figure come could spit outa there occasionally. But most of these replies make me thinkI should keep looking but prepare to get used to it...and stick a towel under there on customers driveways!
Old Mar 30, 2011 | 05:04 PM
RattleBomb7.3's Avatar
its not leaking, just marking it's territory!!!
Old Mar 30, 2011 | 05:23 PM
BIG NIG's Avatar
its sweating horsepower
Old Mar 30, 2011 | 09:19 PM
cummins95's Avatar
its a cummins thing, pretty sure oil leaks are a factory option, along with death wobble straight from dodge
Old Apr 2, 2011 | 06:24 PM
Bill10656's Avatar
Found my leak! from the power steering pump/vacume pump joint. Not what i was expecting... in fact i didn;t realise they were there or joined until i saw the leak! Is either likely to be damaged or will this be all I need?
Dodge Ram Cummins Vacuum Pump Seal Kit, Power Steering on eBay (end time 22-Apr-11 20:46:46 BST)
