VE Pump Fuel Line
Old Dec 9, 2007 | 03:47 PM
LOGANSTANFORTH's Avatar
Default VE Pump Fuel Line
how do you get it off??? i got all the injector lines off, got all but 1 pump bolt left and the fuel line going to the pump, i tried to take it off with a line wrench but the fitting it screws into tries to twist and the line is wanting to start bending, ive tried a few different ways with no results, i am thinking of some heat and PB blaster cause i already got to rebuild the pump so the seals are of no concern.......
second question, how do you get the oil filler neck off without removing the fan????
Old Dec 9, 2007 | 03:49 PM
2001shrtbedcummins's Avatar
Just twist oil neck I think...pb blaster works great on that kinda stuff...hell just use a pair of tin snips.
Old Dec 9, 2007 | 03:51 PM
ok thanks for the filler neck, and no im not cutting the fuel line with tin snips......
Old Dec 9, 2007 | 03:52 PM
so do you know what's wrong with your pump?
Old Dec 9, 2007 | 04:18 PM
nope LOL, gonna tear into it and rebuild it myself, cant be too hard, there aint that many seals and parts in the kit.....i already know where some of the pieces go so that eliminates alot of hassles.....HOPEFULLY the pump will pull out of the gear and it will come out easy.........HOPEFULLY.......
i got it figured out, i took the line loose at the filter block, leave the thread OPEN til i get the rebuild finished......
Last edited by LOGANSTANFORTH; Dec 9, 2007 at 04:19 PM. Reason: Automerged Doublepost
Old Dec 9, 2007 | 05:14 PM
Oh yea just hope and pray it's not like mine was. Some idiot had welded the gear onto the shaft. Got the shaft they broke trying to get it out to prove it.
Old Dec 9, 2007 | 05:56 PM
my pump hadnt been messed with, it still had all the covers' locks and caps on it from the factory so you couldnt adjust it, i just got to get the banjo bolt for the AFC line cause it snapped taking it apart in NC......
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
