92 6.5 losing prime
Old Mar 25, 2011 | 03:58 PM
biged681985's Avatar
Default 92 6.5 losing prime
we have a customer who brought his truck to us and said it wont start with out some either. the glow plugs are woking like there supposed to. if they truck sits for a couple hours, its real hard to start. pretty sure its losing its prime. i cracked an injector line, and it takes a minute of cranking to get fuel out the injector line. i put my hand on the frame mounted lift pump, and its running with the key on. i know that aint a great test, but was just seeing if it was turning on.
now on to what i dont know. if a truck is losing its prime, what would cause this? is the injector pump going out? or is there a return that is supposed to keep it from bleeding of thats causing this?
Old Mar 25, 2011 | 04:13 PM
Crazy's Avatar
check back at tank these truck where knew from over age start sucking air at fuel unit
also just because hear LP don't mean it good
other thing see does do it with a full tank or start do it when fuel gets low
The return lines should run back to pump i would try taking fuel off the back of the LP and run rubber line to 5gal fuel can see if it loosing it prime
Old Mar 25, 2011 | 04:31 PM
also just because hear LP don't mean it good i know it dont, but just a fast check just to see if its running
other thing see does do it with a full tank or start do it when fuel gets low as far as i know, it does it ALL THE TIME
my answers are in red
is there anything in the IP that would cause this?
Old Mar 25, 2011 | 04:44 PM
Crazy's Avatar
if the IP leaking you should see the fuel in the valley check around fuel filter house O-ring go bad and they start to leak let set for few hrs and look in filter house and see how much fuel is there
Brclouse
Nov 18, 2015 08:44 AM
Baradium
Mar 9, 2015 07:15 PM
Levis95
Jan 11, 2015 01:54 AM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
