break off screw on p pump
Old Mar 24, 2011 | 08:42 PM
98dodgecummins's Avatar
Default break off screw on p pump
is the break off screw a bolt head or a head flat head and is it the front bolt or the back
Old Mar 24, 2011 | 10:13 PM
davo79's Avatar
Front upper screw and its neithe use a t18 torx. Bit and an impact driver to remove it then replace it wit a regular metric bolt
Old Mar 24, 2011 | 11:34 PM
EasternAggie's Avatar
Its basically just got a dot in the top of it. You knock the torx bit down into it to force it to the shape of the bit so you can turn it. I guess you could use a t18, but Ive heard t15 also.
Old Mar 25, 2011 | 10:17 PM
HAYMAFIA's Avatar
if you use a sharp chisel and hit the top of the screw you can use a flthead screwdriver to get it out
Old Mar 26, 2011 | 10:23 AM
Many different methods
Old Mar 26, 2011 | 10:29 AM
davo79's Avatar
There are many the torx bit works best and beside you really need the impact driver to get the plate screws loose imo
Old Mar 27, 2011 | 06:37 PM
tower_ofpower's Avatar
yeah, tried just the torx... stripped it out, chiseled a flat head, screw driver didnt do the trick so i wound up using the chisel and hammer to turn the screw out, it comes out eventually
Old Mar 27, 2011 | 11:55 PM
determination is the solution to nearly anything
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
moneypitk5
Feb 12, 2015 11:01 AM
93cummins12v
Dec 22, 2014 11:06 PM
