Programmer and Tuner Question
Old Mar 23, 2011 | 04:40 PM
zach2's Avatar
Default Programmer and Tuner Question
I have enjoyed the mild tuning mods and Hypertech program on stage 3 for several years now. I want to know how a set of mildly performance injectors will change things. Horsepower and torque. EGTs. MPGs!!! Stock clutch with 210k miles on it. Is a hotter program better, easier, and cheaper? What do yall think?
Old Mar 23, 2011 | 06:59 PM
KillStroker's Avatar
Well the injectors are gonna give you increase hp/tq, and depending how you drive better mpgs. But your gonna have higher egts if you dont have a A/F turbo that would support this added fuel. If I was you I would get a btr clutch than add the power thats just me. Plus a more aggresive tuner that taps into your injector pump, better fuel sticks and a turbo and your gonna see a big increase. Depending on if you constantly gettin on the fuel pedal will make the differenced if your stock clutch last.
Old Mar 23, 2011 | 08:54 PM
zach2's Avatar
I appreciate your info, Killstroker. I'm really looking for a much less extreme (expensive) increase in power. Have I already reached the point to where that's my only option? Hypertech, 4" exhaust without muffler, BHAF, and Raptor 100 lift pump is my list of mods.
Old Mar 23, 2011 | 09:12 PM
1st_gen_puller's Avatar
what about guages???? If not then a EJWA would be a great choice with a supprting clutch.. Fill out your sig!!!!!!!!!
Old Mar 23, 2011 | 09:51 PM
zach2's Avatar
Ha! You're right! I do need to fill out my profile. I have got pillar mounted pyro and boost gauges.
Old Mar 24, 2011 | 12:14 AM
then u cant beat a comp box...IMO or maybe even a smarty revo..
Old Mar 24, 2011 | 05:18 AM
zach2's Avatar
Thanks. Will the Comp box compensate for tire size? Can l get that from my Hypertech and use them both?
Old Mar 24, 2011 | 06:41 AM
I think you can use them both but I would use the Comp box for fuel/timing and the hypertech on stock but for your tires and gearing. U need to check to see if they will stack first. My second thought is you could just get a diff tire size compensator that doesnt plug into your OBD port?????
Old Mar 24, 2011 | 02:25 PM
zach2's Avatar
If they are compatible, what change in fuel mileage can I expect and what about VP44 longevity? For my info, when do I look at larger injectors?
Old Mar 24, 2011 | 03:36 PM
Well Its avertised at 2-3 mpg depending upon driving style?????? Thats up to you to debate and people on here will probably chime in. I know I have an edge on mine and just plugging it on stock lvl the truck is just a smoother operator. I would say ive gotten a lil increase in fuel but I put a Airdog 150 in as well so its hard to say about getting btr mileage. The AD says the the same mileage increase. But have I seen a 4-6 increase with the 2? ...no. I generally get 23mpg on the "make a wish overhead counter". Running it on the Mileage lvl.
As far as the VP44 There is some stickys all about VP44's at the begining of the discussion board.
https://www.dieselbombers.com/24-val...formation.html Direct Link.
Get a Fuel pressure gauge yesterday.
Injectors well its hard saying for future I assume your running the stock turbo. Id stick to 50hp-100hp sticks unless you plan for an upgraded turbo and tranny work in the future. I plan on getting 150 sticks soon but had to pay for Hot water heater. I also saving for a turbo and tranny. I just found out that Goerend Tranny is only and hour from my house.
