installing a fass lift pump
Old Mar 20, 2011 | 08:54 AM
radar's Avatar
Default installing a fass lift pump
hi,i have a Fass inline lift pump to install and was wondering if the location along the frame matters.can i put it close to the fuel tank or closer to the eng.thanks
Old Mar 20, 2011 | 10:40 AM
cummins army's Avatar
when i installed my airdog on my last truck i put it as close to the tank as possible the reason for this is a pump is meant to push not pull makes it easier on the pump so it will last longer
Old Mar 20, 2011 | 01:21 PM
radar's Avatar
thank you cummins army,that will give me more room to drill the frame to mount the bracket.
Old Mar 20, 2011 | 01:53 PM
Red_Rattler's Avatar
High Tech Redneck
dont drill into the frame... They make the setup so you dont have to do that
Old Mar 20, 2011 | 03:07 PM
radar's Avatar
hi red,the instructions say to drill frame to mount a bracket.do these pumps need to sit virtigo or can i install horizontal.both ports are at one end of the pump
Old Mar 20, 2011 | 03:11 PM
High Tech Redneck
wow, that sucks... both my airdogs came with nice brackets. Should be mounted so the filters point down
Old Mar 20, 2011 | 03:21 PM
radar's Avatar
its just a inline ddrp04 with out the fiters.
i also sent you a pm
ok i think im going to mount it by the tank.i will have to cut a section of steel fuel line to run rubber hose to the pumps in and out ports.my concern is using hose clamps on the cut metal ends.will the pressure push the hose off?
Old Mar 20, 2011 | 06:22 PM
coors_man_2005's Avatar
i wouldnt cut and splice it in just buy the hose kit that runs from tank to the engine then you will have bigger lines from tank to the filter my thought
Old Mar 20, 2011 | 08:45 PM
High Tech Redneck
Pm sent back, the way the kit is setup is fine and will work like its suppose to, I wouldnt worry about relocating and reengineering what they already tested and made work.
Old Mar 20, 2011 | 10:11 PM
radar's Avatar
the spot by the tank gives me more room,(cant get my drill in where they sugest to mount it) i will still be able to use the quick connect thay supplied,just have to cut out a 8" section of fuel line.i can wire a longer harness to reach the oem plug.just wondering if it makes a differance with this pump(DDRP04 fass pump)if it needs to be up at the eng or can be at the tank.
