Wheel questions
Old Mar 16, 2011 | 11:43 PM
Ford-hoss_cannon's Avatar
Default Wheel questions
What is the bolt pattern on a 1993 f-250? And will 05 dodge 3/4 ton rims fit on it?
Old Mar 17, 2011 | 06:42 AM
DieselCrawler's Avatar
not stock ones. the center hole on them is not large enough.
our lug pattern is 8 on 6.5. any ftermarket rim will work, but stock chevy or dodge will not git without some modifacation.
Old Mar 17, 2011 | 07:49 AM
Oh. Okay. What kind of mod does it take?
Old Mar 17, 2011 | 08:45 AM
you need to open up the center hole. i had a set of h2 rims on my ford for a while. needed to open the center hold up about a 1/4 inch. maybe a little less. used a carbide bit on an angle air grinder and opened it up. took some time but it worked.
Old Mar 17, 2011 | 09:58 AM
Okay. Well what stock rims will fit? Or will I have to just get some and grind them down?
Old Mar 17, 2011 | 10:22 AM
only stock fords will fit a ford. the hubs are larger. but any aftermarket ones will fit.
Old Mar 17, 2011 | 02:17 PM
Before 99 fords right? Cause in 99 they went to 170 bolt pattern right?
And is it possible to take the turbo off and like a 97 powerstroke and put it on my rig?
Last edited by Ford-hoss_cannon; Mar 17, 2011 at 02:17 PM. Reason: Automerged Doublepost
Old Mar 17, 2011 | 05:35 PM
yes, pre 99 will work. anything witht he 8x6.5 pattern and a large enough center hole
as for the turbo, it can be made to work, but will end up costing more than a used kit.
will not just bolt onto the engine.
Old Mar 17, 2011 | 08:37 PM
Okay well where can I fond a fairly cheap turbo kit?
Old Mar 18, 2011 | 07:24 AM
craigslist, ebay, and check in the marketplace at oilburners.net . there is almost always one for sale there.
Mar 20, 2015 08:20 AM
6.5dieselman
Feb 26, 2015 04:45 PM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
