superduty leafsprings on obs?
Old Mar 16, 2011 | 08:10 PM
catfish's Avatar
Question superduty leafsprings on obs?
who do you go y doing this i have been looking around but dont realy understand i have a 94 f250 and it has 3" springs but my 96 f250 has 2 1/2" springs other forums say they just bolted them right in but i dont understand how since they are to different sizes????
any help or ideas with the front suspension wanting to swap to a dana 60... where to locate the leafspring hanger or kits that would work
going with 8" lift in front 6" in the back
Old Mar 16, 2011 | 09:20 PM
oneton's Avatar
what are you asking?it may help to preview your post before you post it,so people can understand what info you are looking for.
Old Mar 16, 2011 | 09:59 PM
joebob3093's Avatar
Moderator
i dont understand that at all
Old Mar 16, 2011 | 10:04 PM
catfish's Avatar
sorry i have a 1996 f150 but it is a crew cab short bed. i am wanting to put a lift on it but the highest lift they make is a 6" inch. i want to go with 8" inches of lift so superduty leafsprings will work.
the springs on the f150 are 2 1/2" wide and the superduty's are 3" inches wide.
people say that they just swap springs and thats it but i dont understand how, if they are two different size widths. how can you make them fit.
also the f150 has the coilspring up front and i want to replace that with a solid dana 60 axle with leafsprings and need to know where to put the hangers for it.
any idea how long the rear driveshaft will have to be lengthened to. what about a drive shaft for the front because it is only a 2wd(putting a 4x4 tranny in)
any advice appreciated!!!!
Old Mar 17, 2011 | 01:30 AM
joebob3093's Avatar
Moderator
Default Re: superduty leafsprings on obs?
You have to weld all new hangers for the SD leaf springs. I didn't know they made a crew cab f150 in an OBS.
Old Mar 17, 2011 | 01:02 PM
catfish's Avatar
it is a centurion with a 5.8 in it any sites with cheap sd hangers?
Old Mar 17, 2011 | 07:52 PM
oneton's Avatar
not trying to discourage you,but you have alot of work instore for that.
maybe you would be better of trying to find a f250 4wd frame and/or a donor truck.then you could swap bodies and other stuff.
find a f250 or f350 locally to take measurements from.best thing to do would be find a f350 truck for all the hangers and assorted parts you will need.(spring hangers,trans and case,etc)
rear driveshaft,you will need to finish suspension too take neasurements.in the front you could do a rsk 5.5in kit with 3-4in springs for your lift.
Old Mar 19, 2011 | 05:34 PM
catfish's Avatar
i fond a kit on sky manu. and it is for leaf springs
Chevy/Ford or Domestic leaf spring hangers, 3 inch or 3.5 ID, tapered to slide over rocks.
1/2 inch bolt holes, not a mount from another vehicle, saves hours over building your own.
Constructed of laser cut and CNC formed 1/4 plate steel.
Shipped as raw steel.
would this work for front and rear and just weld it to the frame and bring the rear leaf closer to the frame.
but the sway bar links that go the the frame would be in the way so i could move the sway bar links strait under the frame with shock tabs
Old Mar 25, 2011 | 07:34 AM
DieselCrawler's Avatar
one issue u will have is on the front axle. unless u redo the frame, or run coils in front, u will not be able to bolt or weld in spring perches. behind your front bumper is a crumple zone. the frame is acordioned. thats where the leafspring mount should go.
2wd to 4wd swap isnt that hard. i have done 3 of them now. the last one( my ford in my sig) took me 2 days to complete from 2wd to 4wd and out the door.
ish1521
Aug 26, 2015 08:42 PM
savage87
Wanted To Buy (WTB) - Used
May 31, 2015 12:39 PM
Slim Whitey
Mar 3, 2015 06:15 PM
pointb912
Diesel Engine Conversions
Jan 17, 2015 01:54 PM
Nov 28, 2014 09:50 PM
