99-03 7.3L Performance Discussion of 99-03 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
injectors
Old Mar 15, 2011 | 10:42 PM
Bigred7.3's Avatar
Default injectors
i removed all 8 injectors on my truck today because im getting new ones, but i knoticed all 8 injectors are AD code i thought the 8th cylinder was suposed to be an AE code injector, what effect does this have on my motor with them all being AD code
Old Mar 15, 2011 | 10:58 PM
95powersmoker's Avatar
Nothing to worry about. The AE was introduced into the #8 cylinder to help reduce cackle. You are fine.
Old Mar 16, 2011 | 04:36 PM
Lange503's Avatar
yeah what he said, nothin to worry about, just something they did to try and cut down on the diesel chatter
Old Mar 16, 2011 | 10:56 PM
OceanDiesel's Avatar
When I pulled all mine, they were AD's (an E-99 had AB's) except #8 which was an AB.
Old Mar 16, 2011 | 11:04 PM
In that case, either it was truly an AB which would have injected a little less fuel than all your AD's...OR somebody replaced it with a rebuilt AD injector with an AB solenoid on it.
Old Mar 17, 2011 | 10:11 PM
Bigred7.3's Avatar
ok cool just wondering, i got all the injectors in and the motor all togather, but its still blowing blue/grey smoke out the tail pipe, when i took the turbo pipes off there was a bit of oil sitting in the pipes, im pretty sure the seals in the turbo are shot, would that be the reason for the smoke?
Old Mar 17, 2011 | 10:35 PM
joebob3093's Avatar
Moderator
how long ago did you replace the injectors?
Old Mar 18, 2011 | 12:03 PM
Bigred7.3's Avatar
2 days ago. but it was smoking like that b4 i replaced the injectors. and the truck still has a miss,
Old Mar 18, 2011 | 12:45 PM
joebob3093's Avatar
Moderator
Default Re: injectors
You might need to replace a under valve cover harness
Old Mar 18, 2011 | 05:14 PM
Lange503's Avatar
or possibly an IDM?
