7.3 high idle
Old Mar 15, 2011 | 03:28 PM
jakobengland's Avatar
Default 7.3 high idle
Is there a way to put an on off high idle switch on an 1999 7.3?
just thinking it would be nice to be able to go to high idle at the flip of a switch.
Old Mar 15, 2011 | 05:06 PM
95powersmoker's Avatar
Having a chip with a high idle position is the easiest way to go...
Old Mar 15, 2011 | 06:53 PM
Lange503's Avatar
what he said, also i think its Dfuser that has a high idle controller? but i have a 6 pos. chip with the high idle as one of them and i love it, start the truck, wait a few seconds then switch it to high idle
Old Mar 15, 2011 | 09:31 PM
OceanDiesel's Avatar
I have it on a 6-POS as well, plus mine will go to high idle on it's own when it's cold outside, I tap the brake pedal and it returns to normal RPM.
Old Mar 15, 2011 | 10:50 PM
fordornothing's Avatar
mine automaticallly idles up. even when it's alread warm.
Old Mar 22, 2011 | 01:30 AM
Clark Kent's Avatar
Same here. My 99 seems to occasionally idle up after warm so I guess this is normal?
Old Mar 23, 2011 | 11:38 AM
rmarini21's Avatar
you can get an rpm controller from that were intalled on trucks with pto and ambulances as a charge protect. I pulled one out of a junak ambualance at work my truck already had the harness und the dash and it was just plug and play you can adjust your desired rpm as low as 1200. here is a pic of it
Old Mar 23, 2011 | 12:01 PM
CSIPSD's Avatar
Once the oil temp is warm, and the air temp outside is warm it should not go back into the high idle setting... If the air temp is still cold they will go into high idle again to maintain the oil temp
Attachment 20142
The AIC is a very cool unit, and if you can get one cheap then go for it... But they are about $150-$400...
You can buy a chip and install a High Idle setting on it for about $450 or so. Then you can have 5 power settings plus a high idle.
Old Mar 23, 2011 | 02:13 PM
PSD7.3's Avatar
haha, i made a rod so i could hold the break on when its warming up to let my neighbors sleep! 4'' turbo back straight. sounded like a jet trying to take off
Old Mar 24, 2011 | 12:47 AM
Lange503's Avatar
if my neighbor wasn't a complete a$$ i might be more concerned on what they think BUT they are the way they are soooo i just let it warm up on my high idle during the winter
