Diesels On The Dyno Diesel Discussions of Dynoing , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST EVENTS IN THIS SECTION*
need some dyno advice
Old Mar 15, 2011 | 01:37 PM
codyawise's Avatar
Default need some dyno advice
i never had my truck on the dyno want to though so i can know what i got
so what advice can you give me once i do dyno my truck.
its a 97 powerstroke 5 speed
Old Mar 18, 2011 | 10:31 PM
j son's Avatar
be more spasific on what it is you need advice
Old Mar 19, 2011 | 05:11 AM
reiser's Avatar
Miller Lite Drinkin'Coach
being a five speed you wanna dyno in your closest 1:1 ratio so prob. forth gear, just back or pull on the rollers let them strap her down they'll tell you when to go head and get them turning and run her up to forth let it sit there and the'll give you the ok.... Then push the skinny pedal to through the floor... Easy as pie.
Old Mar 31, 2011 | 06:06 PM
sstockton's Avatar
Depends on the dyno and operator. I would say, try to have your boost up pretty significantly before you start your run. Or at least be at the point that your turbos have started spooling and will light quickly once you start your run. Being able to build proper load goes a long ways.
Sean
Blair@BD
BD-Power
Sep 11, 2015 02:07 PM
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
May 6, 2015 05:11 AM
twm011
Feb 24, 2015 09:11 AM
